Hi all,
Adressbuch -> Rechtsklick auf einen Kontakt -> zu Kategorien hinzufügen -> keine Reaktion
apache errorlog:
[Sun Jul 13 09:57:46.392990 2014] [:error] [pid 6869] [client 192.168.0.2:49641] PHP Warning: preg_match() expects parameter 2 to be string, array given in /var/www/egroupware/etemplate/inc/class.etemplate_widget.inc.php on line 477, referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393033 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #1 /var/www/egroupware/etemplate/inc/class.etemplate_widget.inc.php(477): preg_match(’/legacy_actions…’, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393042 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #2 /var/www/egroupware/etemplate/inc/class.etemplate_widget_grid.inc.php(79): etemplate_widget::check_disabled(’!@nm[selectcols…’, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393051 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #3 /var/www/egroupware/etemplate/inc/class.etemplate_widget_grid.inc.php(146): etemplate_widget_grid->run(‘validate’, Array, true, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393059 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #4 /var/www/egroupware/etemplate/inc/class.etemplate_widget_grid.inc.php(146): etemplate_widget_grid->run(‘validate’, Array, true, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393067 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #5 /var/www/egroupware/etemplate/inc/class.etemplate_widget.inc.php(428): etemplate_widget_grid->run(‘validate’, Array, true), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393073 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #6 /var/www/egroupware/etemplate/inc/class.etemplate_widget_template.inc.php(230): etemplate_widget->run(‘validate’, Array, true), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393091 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #7 /var/www/egroupware/etemplate/inc/class.etemplate_new.inc.php(277): etemplate_widget_template->run(‘validate’, Array, true), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393098 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #8 [internal function]: etemplate_new->ajax_process_content(‘addressbook_han…’, Array, false), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393104 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #9 /var/www/egroupware/phpgwapi/inc/class.egw_json.inc.php(164): call_user_func_array(Array, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393112 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #10 /var/www/egroupware/phpgwapi/inc/class.egw_json.inc.php(83): egw_json_request->handleRequest(‘addressbook.ete…’, Array), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393119 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #11 /var/www/egroupware/json.php(103): egw_json_request->parseRequest(‘addressbook.ete…’, ‘{“request”:{"pa…’), referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393126 2014] [:error] [pid 6869] [client 192.168.0.2:49641] #12 {main}, referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
[Sun Jul 13 09:57:46.393139 2014] [:error] [pid 6869] [client 192.168.0.2:49641] # Instance=default, User=hansa, Request=POST https://www.poppix.de/egroupware/json.php?menuaction=addressbook.etemplate_new.ajax_process_content.etemplate, User-agent=Mozilla/5.0 (Windows NT 6.1; WOW64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/35.0.1916.153 Safari/537.36, referer: https://www.poppix.de/egroupware/index.php?menuaction=addressbook.addressbook_ui.index&ajax=true
Öffnet man den Kontakt und editiert die Kategorie im Tab ‘Details’ geht es.
r47627
Gruß
Hansa
