Hallo Manfred,
vielen Dank für die Antwort!
Ich habe es schon versucht, dann kommt folgende Meldung:
“Invalid SQL: REPLACE INTO egw_addressbook (contact_tid,contact_owner,contact_private,cat_id,n_family,n_given,n_middle,n_prefix,n_suffix,n_fn,n_fileas,contact_bday,org_name,org_unit,contact_title,contact_role,contact_assistent,contact_room,adr_one_street,adr_one_street2,adr_one_locality,adr_one_region,adr_one_postalcode,adr_one_countryname,contact_label,adr_two_street,adr_two_street2,adr_two_locality,adr_two_region,adr_two_postalcode,adr_two_countryname,tel_work,tel_cell,tel_fax,tel_assistent,tel_car,tel_pager,tel_home,tel_fax_home,tel_cell_private,tel_other,tel_prefer,contact_email,contact_email_home,contact_url,contact_url_home,contact_freebusy_uri,contact_calendar_uri,contact_note,contact_tz,contact_geo,contact_pubkey,contact_created,contact_creator,contact_modified,contact_modifier,contact_id) VALUES (‘n’,-2,0,‘25,27,28’,‘Graf’,‘Andreas’,NULL,‘Herr’,NULL,‘Herr Andreas Graf’,‘Graf & Naydis Rechtsanwälte: Graf, Andreas’,NULL,‘Graf & Naydis Rechtsanwälte’,NULL,‘Rechtsanwalt’,‘Inhaber’,NULL,NULL,‘Mozartstraße 17’,NULL,‘München’,NULL,‘80336 ‘,‘GERMANY’,NULL,NULL,NULL,NULL,NULL,NULL,NULL,’+49-89-74 74 79 01’,NULL,’+49-89-76 70 10 99’,NULL,NULL,NULL,NULL,NULL,NULL,NULL,NULL,‘ra.andreas.graf@lawyer-munich.de’,‘ra.ivan.naydis@lawyer-munich.de’,‘http://www.lawyer-munich.de/’,NULL,NULL,NULL,NULL,‘0’,NULL,NULL,1288080587,6,1298299599,6,'contact_etag=contact_etag+1’,35):
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'contact_id) VALUES (‘n’,-2,0,‘25,27,28’,‘Graf’,‘Andreas’,NULL,‘Herr’,NULL,'Herr ’ at line 1”
