Moin.
Frische Install, patch installiert wegen Importprofil, Importprofil anlegen geht.
Adressimport aus csv schlägt immer noch fehl mit der Meldung
Eine Anfrage an den EGroupware Server ergab einen Fehler: Internal Server Error (500)
Bitte laden Sie die EGroupware Oberfläche neu (F5 / Cmd+r).
Wenn der Fehler weiterhin auftritt, bitten Sie Ihren Administrator um Hilfe und das Fehler-Protokoll (error-log) des Webservers anzuschauen.
URL: /egroupware/json.php?menuaction=importexport.importexport_import_ui.import_dialog.et2_process
date: Wed, 11 Jan 2023 19:49:58 GMT
Fehlermeldung aus error.log
2023/01/11 19:59:11 [warn] 22#22: *1180 a client request body is buffered to a temporary file /var/cache/nginx/client_temp/0000000008, client: 172.18.0.1, server: _, request: “POST /egroupware/json.php?menuaction=EGroupware\Api\Etemplate\Widget\File::ajax_upload&resumableChunkNumber=1&resumableChunkSize=33030144&resumableCurrentChunkSize=363533&resumableTotalSize=363533&resumableType=application%2Fvnd.ms-excel&resumableIdentifier=363533-egw_export_addressbook-2023-01-11csv&resumableFilename=egw_export_addressbook-2023-01-11.csv&resumableRelativePath=egw_export_addressbook-2023-01-11.csv&resumableTotalChunks=1&request_id=importexport_sysop_uPJQdtPgIi48wukm6HlkJSDMkh0AC8tDle6NC0zKB6A%3D&widget_id=file HTTP/1.1”, host: “xxx.online-server.cloud”, referrer: "https://xxx.online-server.cloud/egroupware/index.php?menuaction=importexport.importexport_import_ui.import_dialog&appname=addressbook"
2023/01/11 19:59:15 [error] 22#22: *1180 FastCGI sent in stderr: “
PHP message: PHP Fatal error: Allowed memory size of 180355072 bytes exhausted (tried to allocate 20480 bytes) in /usr/share/egroupware/importexport/inc/class.importexport_import_csv.inc.php on line 537
PHP message: PHP Fatal error: Allowed memory size of 180355072 bytes exhausted (tried to allocate 24576 bytes) in Unknown on line 0” while reading response header from upstream, client: 172.18.0.1, server: _, request: “POST /egroupware/json.php?menuaction=importexport.importexport_import_ui.import_dialog.et2_process HTTP/1.1”, upstream: “fastcgi://172.18.0.3:9000”, host: “xxx.online-server.cloud”, referrer: “https://xxx.online-server.cloud/egroupware/index.php?menuaction=importexport.importexport_import_ui.import_dialog&appname=addressbook”
Das mit dem memory size hatten wir schon probiert, selbst 512MB brachten keine Änderung, weswegen ich mal davon ausgehe, daß es noch was anderes ist.
Und so groß ist die Importdatei nun auch wieder nicht, ca. 1500 Datensätze und 400kB
Kann das wenigstens jemand nachvollziehen?
Danke
Jürgen
