Hello Together,
after a fresh install of 20.1 on my laptop I get the following error when accessing the calendar application.
2020/08/10 08:49:56 [error] 6#6: *352 FastCGI sent in stderr: "PHP message: An error happened! (Error): Call to undefined method EGroupware\Status\Videoconference\Call::getMeetingRegex()
PHP message: #0 [internal function]: calendar_ical->_ical2egw_callback(Object(Horde_Icalendar_Vevent), 'Europe/Berlin', '', Object(EGroupware\Api\CalDAV\IcalIterator))
PHP message: #1 /var/www/egroupware/api/src/CalDAV/IcalIterator.php(205): call_user_func_array(Array, Array)
PHP message: #2 /var/www/egroupware/calendar/inc/class.calendar_holidays.inc.php(85): EGroupware\Api\CalDAV\IcalIterator->current()
PHP message: #3 /var/www/egroupware/calendar/inc/class.calendar_holidays.inc.php(55): calendar_holidays::render('DE', 2019, 2025)
PHP message: #4 /var/www/egroupware/calendar/inc/class.calendar_bo.inc.php(1893): calendar_holidays::read('DE', 2020)
PHP message: #5 /var/www/egroupware/calendar/inc/class.calendar_ui.inc.php(569): calendar_bo->read_holidays(2020)
PHP message: #6 /var/www/egroupware/calendar/inc/class.calendar_ui.inc.php(504): calendar_ui->sidebox_etemplate()
PHP message: #7 /var/www/egroupware/api/src/loader/deprecated_factory.php(131): calendar_ui->sidebox_menu(Array)
PHP message: #8 /var/www/egroupware/api/src/Hooks.php(143): ExecMethod2(Array, Array)
PHP message: #9 /var/www/egroupware/api/src/Framework/Ajax.php(568): EGroupware\Api\Hooks::single(Array, 'calendar')
PHP message: #10 /var/www/egroupware/api/src/Framework/Ajax.php(466): EGroupware\Api\Framework\Ajax->get_sidebox('calendar')
PHP message: #11 /var/www/egroupware/api/src/Framework/Ajax.php(1012): EGroupware\Api\Framework\Ajax->do_sidebox()
PHP message: #12 [internal function]: EGroupware\Api\Framework\Ajax::ajax_exec('index.php?menua...')
PHP message: #13 /var/www/egroupware/api/src/Json/Request.php(192): call_user_func_array(Array, Array)
PHP message: #14 /var/www/egroupware/api/src/Json/Request.php(104): EGroupware\Api\Json\Request->handleRequest('calendar.jdots_...', Array)
PHP message: #15 /var/www/egroupware/json.php(125): EGroupware\Api\Json\Request->parseReque
I checked the code and can confirm that getMeetingRegex() is in place.
What could I do to solve this?
Thank you for your support!
BR
Alex
