Unfortunately, I have made use of it in more then one spot and only
the one
spot requires the extra length. I guess a quick hack would be to
make an
ajax select(2) in my installation copying the widget and templates
with a
different name then extending the etamplate in the copy.
You could also try using CSS to change the input box’s size. That
might work better.
Nathan Gray
nathan at goarctic dot com
This SF.net email is sponsored by:
SourcForge Community
SourceForge wants to tell your story.
http://p.sf.net/sfu/sf-spreadtheword
