I just realised that for users to be able to use the Ajax Select
Widget, they require access to the etemplate application. This is
quite a concern because while I am ok for my end users to use the
Ajax Select Widget, I do not want them to be able to edit templates.
Is this something that needs to be looked at in more details?
I’m pretty sure this was fixed rev. 24469. Our users don’t have
etemplate access, and it works.
And, to cross threads, that dynamic table is starting to look really
nice. One more feature (you’ve probably heard it already) that would
be nice is if clicking “+” added the row below the row that was
clicked, instead of the end.
Nathan Gray
nathan at goarctic dot com
Extra punctuation??? Ug!!!
Just say no! Punctuation marks do not gain significance if you
increase their number, they make you look silly. One is sufficient.
It’s the best place to buy or sell services for
http://ad.doubleclick.net/clk;164216239;13503038;w?http://sf.net/marketplace
