Thank you for the advice.
We have created a new ,header,
But it’s not me update mysql.
process->pass(): #1 for upgrade processing
process->upgrade(): Incoming : appname: api, version: 14.3.907, status: U
process->upgrade(): api(14.3.907 --> 16.1.005): running api_upgrade14_3_907() --> 16.1
process->upgrade(): api(16.1 --> 16.1.005): running api_upgrade16_1()
AlterColumnSQL(‘egw_ea_accounts’,‘acc_folder_archive’,Array ( [type] => varchar [precision] => 128 [comment] => archive folder ) ) sql=Array ( [0] => ALTER TABLE egw_ea_accounts ADD acc_folder_archive VARCHAR(128) )
Duplicate column name ‘acc_folder_archive’
–> 16.1.001
process->upgrade(): api(16.1.001 --> 16.1.005): running api_upgrade16_1_001() --> 16.1.002
process->upgrade(): api(16.1.002 --> 16.1.005): running api_upgrade16_1_002() --> 16.1.003
process->upgrade(): api(16.1.003 --> 16.1.005): running api_upgrade16_1_003() --> 16.1.004
process->upgrade(): api(16.1.004 --> 16.1.005): running api_upgrade16_1_004()
Invalid SQL: SELECT fs_id,prop_namespace,prop_name,MAX(prop_id) AS prop_id
FROM egw_sqlfs_props
GROUP BY fs_id,prop_namespace,prop_name
HAVING COUNT(*) > 1
Unknown column ‘prop_id’ in ‘field list’ (1054)
Instalovat/odstranit/aktualizovat aplikaci:
Duplicate column name 'acc_folder_archive’
Database error
HAVING COUNT(*) > 1
