Yann Lehmann wrote:
Ken Smith wrote:
Hi All,
My mobile provider has sent me a HTC Desire, so I’ve been trying it out
with the Synthesis SyncML software and eGW.
I have the same problem, that others have reported, that eGW events
appear on the phone just fine, but events created on the phone vanish
after sync.
In egw, under syncml options, you can define which part of the
synchronization “wins” (device or server). You have to change it to
’merge’ for the calendar (don’t know exactly how it is called, my egw is
in german).
Yes its Merge in the English version and that is how mine is set.
Yes, it does pretty good with the Synthesis app.
Yann
Thanks Yann,
I’m still getting vanishing appointments. Egw is 1.8.001 (this is a test
system - not production), Android is 2.3.3, Synthesis is 2.2.13.
In Synthesis the Events Sync Mode is Normal, path is ./calendar
I’m using https.
Do you have similar versions/settings?
Thanks
Ken
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Try before you buy = See our experts in action!
The most comprehensive online learning library for Microsoft developers
is just $99.99! Visual Studio, SharePoint, SQL - plus HTML5, CSS3, MVC3,
Metro Style Apps, more. Free future releases when you subscribe now!
http://p.sf.net/sfu/learndevnow-dev2
