The first solution I have gave was not good at all
SO I have look deeper in the code and test it in production for few day
and now it seem to be ok
in fact we need to add before line 122 " if
(isset($event[‘participants’][$user]) && ($show_rejected ||
$event[‘participants’][$user] != ‘R’))"
this line
$boCalendar->enum_groups($event);
to get all the participant from the group add
If you have use le patch from
(http://k.noc.de/index.php?option=com_content&view=article&id=6)
you need to add it before line 244
if ((!$startDate || $startDate <= $event[‘start’]
&& $event[‘end’] <=
$endDate)
zorg a écrit :$boCalendar->enum_groups($event);
Like i have explain in a mail before
Here is the problem
When someone invite a group of partipicant if he had no right on this group
then the calendar event added can’t be synchronized by the member of
the group but it appear on the calendar without problem
the event get sync if the member accept the event
after looking in the code I think i have found why
in file
syncml/calendar/lib/api.php
line 122
we have
if (isset($event[‘participants’][$user]) && ($show_rejected || $event[‘participants’][$user] != ‘R’))
the problem is if the event comming from the search (calendar_bo_inc.php) contain onky a group (from the user) the participant didn’t answer
$event[‘participants’][$user] is not true
for me the solution would be to write only (because everything is filter before with the search)
if ( ($show_rejected || $event[‘participants’][$user] != ‘R’))
hope it help
Crystal Reports - New Free Runtime and 30 Day Trial
Check out the new simplified licensing option that enables unlimited
royalty-free distribution of the report engine for externally facing
server and web deployment.
http://p.sf.net/sfu/businessobjects
