Ralf, All,
In the past, when mobile users added a contact, it always was entered into
the users ‘personal’ address book requiring the users to later edit the entry
and change the setting to ‘group default’ (you can imagine how many times
somebody ‘forgot’ to do that). It was my understanding at the time that this was
a system limitation of the way the remote groupdav access worked and it could
not be changed. Is there any way now to configure the groupdav interface so that
when mobile users add a contact it is added under ‘group default’ and available
to all other users?
Basically I want all addresses added by remote users to be added under ‘group
default’ and if someone wants to add an address as ‘personal’ they can
individually do that via the PC. (it’s hard enough to get people to take the
time to add a contact in the first place, much less add AND edit each contact
This will eliminate the burden that EVERY address added by mobile users be
edited again on the PC to change the setting the ‘group default’.
If there is a file I can hack to accomplish this – that’s fine too.
I guess this default makes sense in some organizations, but for small to
medium companies making contacts entered by mobile users available to all by
default makes the most sense. Any way to do this now, or is it still just a
limitation?
David C. Rankin, J.D.,P.E.
