You do not have to use etemplates. I did not like the idea of them at first either. I figured that it was some standard html generation.
I designed my whole app without them. Took 4 months (evenings and some weekends). I decided that I want my app to link with the others better so I tried to do a few screens in etemplate. Within one month I completely rewrote my app using etemplates.
My suggestion to you is that you must need some of the features in etemplates. Design your app using etemplates leaving out the feature that you are missing. Then once you are comfortable with them create the etemplate feature you need as a widget. You most lickly will save more time that way. trust me I found out the hard way.
Thanks
Randy
Thanks
Randy
