Are you running async service in “fallback mode”?
I would try running it via cron.
In fallback it executes after regular script execution and can therefore
interfere with a logged in users environment.
I have an issue of using egw_vfs inside of the async function. I am using
the class.uiasyncservice.inc.php as my testing ground for async and I
inserted this code: if(!egw_vfs::is_dir(’/home/ki/my_folder’)) in the test
function. When I start the test job and running the test function of
uiasyncservice, I cannot receive email anymore, the pre-defined email in the
said function. When I’m going to remove the code I inserted, the function
behave normal.
Any thought?
Thanks.
-Ki
View this message in context: http://egroupware.219119.n3.nabble.com/Async-issue-on-egw-vfs-tp3995917.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
Android apps run on BlackBerry 10
Introducing the new BlackBerry 10.2.1 Runtime for Android apps.
Now with support for Jelly Bean, Bluetooth, Mapview and more.
Get your Android app in front of a whole new audience. Start now.
http://pubads.g.doubleclick.net/gampad/clk?id=124407151&iu=/4140/ostg.clktrk
