Hi, I have migrated from EGW 1.6.003 to 1.8.001
Everythink run ok except of reminding by email for EGW users.
Example:
- I planned calendar event and save
- I set one or more reminding for calendar event
- after past time I haven§t any remind message in my mailbox and root has new message:
From apache@localhost.localdomain Fri Mar 11 09:30:01 2011
Return-Path: apache@localhost.localdomain
Received: from localhost.localdomain (groupware [127.0.0.1])
by localhost.localdomain (8.13.8/8.13.8) with ESMTP id p2B8U1xX028605
for root@localhost.localdomain; Fri, 11 Mar 2011 09:30:01 +0100
Received: (from apache@localhost)
by localhost.localdomain (8.13.8/8.13.8/Submit) id p2B8U1is028604;
Date: Fri, 11 Mar 2011 09:30:01 +0100
Message-Id: 201103110830.p2B8U1is028604@localhost.localdomain
To: root@localhost.localdomain
Subject: Cron apache@groupware /usr/bin/php -q /usr/share/egroupware/phpgwapi/cron/asyncwrapper.php
Content-Type: text/plain; charset=UTF-8
Auto-Submitted: auto-generated
X-Cron-Env: <MAILTO=root>
X-Cron-Env: <SHELL=/bin/bash>
X-Cron-Env: <HOME=/var/www>
X-Cron-Env: <PATH=/usr/bin:/bin>
X-Cron-Env: <LOGNAME=apache>
X-Cron-Env: <USER=apache>
calendar_boupdate::send_update error while notifying user Žádné:Error: cannot send notifications. No receivers supplied
What cam be wrong. In 1.6.003 was everything ok!
Thanks for any help.
Ruda
