you use most likely not Apache mod_php, but PHP via (Fast)CGI. This does
not support the required Basic authentication by default.
You can use a rewrite rule like it is described eg here, but using
"Authorisation" instead of “HTTP_AUTHORIZATION”:
http://www.besthostratings.com/articles/http-auth-php-cgi.html
Eg for EGroupware under /egroupware in a .htaccess or Apache vhost file:
RewriteEngine on
RewriteRule ^/egroupware/(web|group)dav.php -
[E=Authorization:%{HTTP:Authorization},L]
Or simply use a provider who has any idea about EGroupware hosting!
Hello,
I have just installed eGroupware on a shared server. eGroupware seems to
work fine as long as the web interface is concerned, but I just can’t access
any shared resources such as CalDAV, CardDAV, files and so on.
If I point my browser to where the resources are located, i.e.
http://www.domain.com/egroupware/groupdav.php/test/calendar/
I get prompted for my username and password, but my credentials are refused
and I eventually get a “Authorization failed.” message.
I figured out that if I go to the Filemanager in the web interface, the
links to the files I have uploaded contain a session ID, i;e;
http://www.domain.com/egroupware/webdav.php/home/test/document.pdf?sessionid=p897q52oru6eiq1qhottbsqhv6&kp3=S6QeVC7XhtXzeEeD8fyoCye4&domain=default
and if I use that session ID in the URL for CalDAV, CardDAV, etc, i.e.
http://www.domain.com/egroupware/groupdav.php/test/calendar/?sessionid=p897q52oru6eiq1qhottbsqhv6&kp3=S6QeVC7XhtXzeEeD8fyoCye4&domain=default
things work fine.
So this is realy an authentication problem. I believe this could have
something to do with the “Authentication / Accounts” settings in the
configuration setup, but I have tried several settings to no avail, and
don’t have enough technical background to fully understand these settings.
Has anyone an idea of what I’ve done wrong?
Thanks a lot
View this message in context: http://egroupware.219119.n3.nabble.com/Authentication-problems-tp3649451p3649451.html
Sent from the egroupware-users mailing list archive at Nabble.com.
Ridiculously easy VDI. With Citrix VDI-in-a-Box, you don’t need a complex
infrastructure or vast IT resources to deliver seamless, secure access to
virtual desktops. With this all-in-one solution, easily deploy virtual
desktops for less than the cost of PCs and save 60% on VDI infrastructure
costs. Try it free! http://p.sf.net/sfu/Citrix-VDIinabox
