Can someone please explain the “best” way to configure the file manager?
There are 3 choices ( “Filesystem” ; “Database”; and “custom set via
filemanager / cli.php mount” )
The first 2 allow you to select where to store file contents (metadata
is allways in database). Recommendation is to leave filesystem, as PHP’s
PDO plugin for MySQL is limited to a couple of MB files
- setting only means you mounted some other filesystems in EGroupware’s
virtual filesystem and can NOT manage it with setup anymore. EPL has
it’s own management tools (Filemanager >> Admin >> Versioning) or in CE
you can use filemanger/cli.php mount for that.
One consideration as the guy who will be in charge if it, I’d like to remove
files / folders when needed regardless of who put them in, and be able to
identify the heavy users. I do not see a way to set limits, so it would be
great to monitor usage.
One last question - I tried to look at versioning, but it says I need to
"become root to enable or disable versioning on a directory"
As user of our EPL version, we are happy to assist you via
https://my.stylite.de/
Who is “root”? I tried my admin login but that fails. I tried mysql user
root user for filemanager is more a role then a real user. By default it
is only the setup user (usually called “admin”) with his password. You
can give other users that role by adding them in setup >> edit current
configuration to “User names, comma-separated, which can get VFS root
access (beside setup user)”. These users can then use their regular
username/password to become root (a bit like sudo in Linux).
Thanks for any input
You are welcome
