Hi David,
Ralf, all,
I was looking at:
http://www.egroupware.org/index.php?page_name=installation_update_instructions&lang=es-es&wikipage=PeerServers
This article contains just ideas, nothing from it has been implemented.
but most of the article is dated 2004. So what is the current best method to
either share or merge 2 egw installs? Ideally I would like to merge the
information, but if setting up simple sharing will allow access of information
from one to the other, then that may provide a better solution.
Any newer links or references will be appreciated. (my install is current
through svn revision 32608 - today)
There’s nothing existing to automatic merge two installs or sync them.
Only solution is to either merge manually or use clients which can show
data from more then one install, eg. CalDAV and CardDAV clients eg. the
ones from Apple.
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Geschäftsführer Andre Keller,
Gudrun Müller, Ralf Becker
Nokia and AT&T present the 2010 Calling All Innovators-North America contest
Create new apps & games for the Nokia N8 for consumers in U.S. and Canada
$10 million total in prizes - $4M cash, 500 devices, nearly $6M in marketing
Develop with Nokia Qt SDK, Web Runtime, or Java and Publish to Ovi Store
http://p.sf.net/sfu/nokia-dev2dev
