Hi
here is the problem when you try to send mail from the address
for example
Select 45 contacts in address book then use the mouse right click
and select Email -> Add To
Because the email are sent using the get method it’s happen that the url
is more than 1083 character so mail are truncate by ie 10 and 11
(https://support.microsoft.com/en-us/kb/208427/).
I suggest to use the post method to get rid of this problem
Hope it help
Cyril
probeSys - spécialiste GNU/Linux
site web : http://www.probesys.com
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
