Hello
Still have the same bug with commit 46719 with chrome
nothing on the log i’musing idots theme
Am i the only one having the bug ??
I have try the demo and it work on chrome
thanks
sorry to bohter you
after testing on Version 31.0.1650 of chrome
it doesn’t
i have minify onr not
after moving a event it stop working
nothing in the log
the only this i found is if i disable the cache when devtool on
it work but it’s slow
hote it help
I ve retest with last trunck everything seem ok
It’s quite strange.
Can you please, check couple of things:
Check your web-server error log, and see if you get any error when d-n-d
stopped working.
When you say, it stops working, are you still able to drag the entry but
it can’t be dropped? or even the dragging is not working too?
None of the browsers that you’re testing with, throws no javascript error
at all?
Please let me know.
regards,
Hadi
EGroupware Developer
View this message in context: http://egroupware.219119.n3.nabble.com/bug-in-calendar-drop-and-drop-tp3995485p3995537.html
Sent from the egroupware-developers mailing list archive at Nabble.com.
WatchGuard Dimension instantly turns raw network data into actionable
security intelligence. It gives you real-time visual feedback on key
security issues and trends. Skip the complicated setup - simply import
a virtual appliance and go from zero to informed in seconds.
http://pubads.g.doubleclick.net/gampad/clk?id=123612991&iu=/4140/ostg.clktrk
probeSys - spécialiste GNU/Linux
site web : http://www.probesys.com
Start Your Social Network Today - Download eXo Platform
Build your Enterprise Intranet with eXo Platform Software
Java Based Open Source Intranet - Social, Extensible, Cloud Ready
Get Started Now And Turn Your Intranet Into A Collaboration Platform
http://p.sf.net/sfu/ExoPlatform
