Hello,
I still have same problem
I someone want to help fix the bug I’m ok to financially contribute.
I m using funambol 7.2.2 on pocketpc and egroupware 1.6 up to date.
When someone invite a group of partipicant if he had no right on this group
then the calendar event added can’t be synchronized by the member of
the group but it appear on the calendar without problem
the event get sync if the member accept the event
thanks
The NEW KODAK i700 Series Scanners deliver under ANY circumstances! Your
production scanning environment may not be a perfect world - but thanks to
Kodak, there’s a perfect scanner to get the job done! With the NEW KODAK i700
Series Scanner you’ll get full speed at 300 dpi even with all image
processing features enabled. http://p.sf.net/sfu/kodak-com
