Ticket modified by balazs zeller at 2014/03/16 08:07
Tracking System: Bugs
Category: Projectmanager
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created by: balazs zeller
Created on: 2013/02/15 11:20
Assigned to: Ralf Becker
Summary: #3210 - Element not showed
after rev41632, if you click on the element in project tree on the left side, the element is not showed on the right side, it is missing completely.
If you click in the project tree on the projet name, you can see the element list on the right side but the project name is missing.
I hope it’s clear what I mean
Best regards,
Balazs
Linked entries:
https://community.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=3210&no_popup=1
