Ticket modified by balazs zeller at 2014/03/16 08:05
Tracking System - Bugs
Category - Filemanager
Version - Trunk
Status - Closed
Resolution - Works for me
Completed - 0%
Priority - 5 - medium
Created by - balazs zeller
Created on - 2013/04/30 08:46
Assigned to - Ralf Becker
Summary - #3227 - After rev 42226 filemanager not working
Hello,
after rev 42226 filemanager is broken, shows no directorys or files, automatically logs you out.
Best regards,
Balazs
Comment by balazs zeller at 2013/07/21 10:58:
Thank you Ralph, that solved my problem.
rgds,
Balazs
Comment by Ralf Becker at 2013/07/21 09:57:
Ok, good to know the cause is minifying.
An other known, but not yet solved problem is: you need run rights for eTemplate app
As for minifying, that’s not intended behavior, it will be fixed before release.
Let me know if that fixes situation for you.
Comment by balazs zeller at 2013/07/21 07:28:
Hi Ralf,
I changed Disable minifying of javascript and CSS files to no, now filamanager is working as admin, but still the same error when I log in as a standard user, logs me out right after I start the filemanager.
Log in java console:
Ajax request to [ https://erp.centralcargo.eu/erp/json.php?menuaction=etemplate_widget_nextmatch::ajax_get_rows::etemplate -> https://erp.centralcargo.eu/erp/json.php?menuaction=etemplate_widget_nextmatch::ajax_get_rows::etemplate failed: parsererror Error
Thanks,
Balazs
Comment by Ralf Becker at 2013/07/17 19:14:
Hi Balazs,
problem is, filemanager is working for me
Have you set “Disable minifying of javascript and CSS files:” to Yes or No?
Comment by balazs zeller at 2013/07/17 11:22:
Java log after SVN update rev 43085
Class {createNamespace: true, init: function, _buildAlignCells: function, loadFromXML: function, assign: function…}
“Attribute ‘options’ does not exist in hbox!” “Error
at Function.debug (https://erp.centralcargo.eu/erp/phpgwapi/js/jsapi/egw_debug.js?1374052526:47:19)
at Class.generateAttributeSet (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_inheritance.js?1374052535:448:9)
at Class.extend.createElementFromNode (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_widget.js?1374052535:673:25)
at Class._readRowNode (https://erp.centralcargo.eu/erp/etemplate/js/et2_widget_grid.js?1374052535:360:24)
at et2_filteredNodeIterator (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_xml.js?1374052535:130:14)
at Class. (https://erp.centralcargo.eu/erp/etemplate/js/et2_widget_grid.js?1374052535:406:6)
at Class.et2_DOMWidget.extend._fillCells (https://erp.centralcargo.eu/erp/etemplate/js/et2_widget_grid.js?1374052535:310:3)
at Class.et2_DOMWidget.extend.loadFromXML (https://erp.centralcargo.eu/erp/etemplate/js/et2_widget_grid.js?1374052535:510:9)
at Class.extend.createElementFromNode (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_widget.js?1374052535:680:10)” egw_debug.js?1374052526:66
Global function is bad! javaScript:nm_not_disableClass egw_action_common.js?1370972575:364
Loading template from XML: filemanager.index.header_left Error
at Object.debug (https://erp.centralcargo.eu/erp/phpgwapi/js/jsapi/egw_debug.js?1374052526:47:19)
at Class.et2_DOMWidget.extend.init (https://erp.centralcargo.eu/erp/etemplate/js/et2_widget_template.js?1374052535:137:16)
at Class.init (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_inheritance.js?1374052535:230:20)
at new Class (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_inheritance.js?1374052535:281:16)
at et2_createWidget (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_widget.js?1374052535:96:9)
at Class.et2_DOMWidget.extend._build_left_right (https://erp.centralcargo.eu/erp/etemplate/js/et2_extension_nextmatch.js?1374052535:1427:16)
at Class.et2_DOMWidget.extend._createHeader (https://erp.centralcargo.eu/erp/etemplate/js/et2_extension_nextmatch.js?1374052535:1311:11)
at Class.et2_DOMWidget.extend.setNextmatch (https://erp.centralcargo.eu/erp/etemplate/js/et2_extension_nextmatch.js?1374052535:1269:8)
at Class. (https://erp.centralcargo.eu/erp/etemplate/js/et2_extension_nextmatch.js?1374052535:1136:11)
at Class.extend.iterateOver (https://erp.centralcargo.eu/erp/etemplate/js/et2_core_widget.js?1374052535:411:14) egw_debug.js?1374052526:54
Ajax request to https://erp.centralcargo.eu/erp/json.php?menuaction=etemplate_widget_nextmatch::ajax_get_rows::etemplate failed: parsererror Error
at json_request.$j.ajax.error (https://erp.centralcargo.eu/erp/phpgwapi/js/jsapi/egw_json.js?1374052526:89:14)
at n (https://erp.centralcargo.eu/erp/phpgwapi/js/jquery/jquery.js?1370972576:2:14784)
at Object.o.fireWith (https://erp.centralcargo.eu/erp/phpgwapi/js/jquery/jquery.js?1370972576:2:15553)
at w (https://erp.centralcargo.eu/erp/phpgwapi/js/jquery/jquery.js?1370972576:4:11420)
at XMLHttpRequest.d (https://erp.centralcargo.eu/erp/phpgwapi/js/jquery/jquery.js?1370972576:4:17218 ])
Comment by balazs zeller at 2013/05/30 09:50:
Hello,
I uploaded the startscreen and the java console of the filemanager, maybe it helps solve the problem. Do you have any idea when this ticket will solved?
Thanks,
Balazs
Linked entries:
https://community.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=3227&no_popup=1
