Ticket modified by Randy T at 2014/02/23 01:46
Tracking System: Bugs
Category: Addressbook
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created by: Randy T
Created on: 2014/01/12 00:42
Assigned to: Ralf Becker
Summary: #3271 - Addressbook Columns Collapsed on Launch
When opening the Addressbook the Columns are Collapsed. See attached screenshot. This occurs with Firefox and Internet Explorer. It seems to be a lingering issue at least in my dev instance from trunk.
Nothing in my apache2 logs that is of value.
One last observation I just stumbled across this when I went to take my screenshot, If I re-size the browser window the Columns render as they should.
: Comment by Randy T at 2014/02/23 01:46:
This issue was related to custom fields in the address book. After deleting the blank “type”, the issue became resolved.
Linked entries:
https://community.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=3271&no_popup=1
