Ticket modified by Tracking System at 2014/05/26 12:00
Tracking System: Bugs
Category: SyncML
Version: Trunk
Status: Closed
Resolution: None
Completed: 0%
Priority: 5 - medium
Created by: Emile Gold
Created on: 2014/04/08 16:29
Assigned to: Jörg Lehrke
Summary: #3277 - syncml won’t work since svn trunk update from 14/04/02
Since you have made chnage to use horde Rpc fonction I receive this error :
PHP Fatal error: Call to undefined method Horde_Rpc::singleton() in /usr/home/www/egroupware/rpc.php on line 108
And previoly you want access to /usr/local/share/horde/RPC.php but the right name is Rpc.php…
Hope this help…
EG
: Comment by Tracking System at 2014/05/26 12:00:
This Tracker item was closed automatically by the system. It was previously set to a pending status and was not responded within 14 days.
: Comment by Ralf Becker at 2014/05/12 11:43:
Hi Emile,
I just commited with r46893 a possible fix for SyncML problem:
RalfsMacBook:egroupware ralf$ svn diff rpc.php
Index: rpc.php
— rpc.php (Revision 46881)
+++ rpc.php (Arbeitskopie)
@@ -13,7 +13,7 @@
@define(‘EGW_API_INC’, dirname(FILE) . ‘/phpgwapi/inc/’);
@define(‘HORDE_BASE’, EGW_API_INC . ‘/horde/’);
require_once HORDE_BASE . ‘/lib/core.php’;
-require_once ‘Horde/RPC.php’;
+require_once HORDE_BASE . ‘/Horde/RPC.php’;
//require_once EGW_API_INC . ‘/common_functions.inc.php’;
Please let me know, if that fixes your problems or what other error you get.
Anyway SyncML is no longer included in 14.1 in favor of eSync / ActiveSync.
Verknüpfte Einträge:
https://community.egroupware.org/egroupware/index.php?menuaction=tracker.tracker_ui.edit&tr_id=3277&no_popup=1
