I’m developping a small module for egroupware 1.6.x and I want to retrieve
timesheets using the timesheet_bo class. My problem is that timesheet_bo
only retrieves timesheets from people current users have right upon. In
example, if some timesheets were created by a user that doesn’t exist
anymore (account deleted), those timesheets won’t be retrieved by the
search() method, as I don’t have rights on this deleted user.
So my question is simple : Is there a way to tell the search() method not to
care about ACLs and retrieve all the timesheets matching my $criteria ?
I could make an alternative timesheet_bo class extending so_sql, but I would
prefer to use the original one.
Thx
View this message in context: http://old.nabble.com/Bypass-timesheet_bo-ts_owner-filter---tp26525327s3741p26525327.html
