1 / 11
Oct 2024
Hi
We noticed an issue with caldav clients. When we book in room resource and change this event to other resource, then the original resource calendar event stuck in caldav client. On the server side the event disappear.
Steps to reproduce:
  • Create an event a caldav client (iPhone, Emclient) with resource booking
  • Synchronize changes
  • Change the resource in event (like other room)
    Result:
    On the caldav client there will be 3 event:
  • Original resource booking
  • New resource booking
  • Own event
    On server:
  • New resource booking event
  • Own event
Additional setting: Sync all resource calendar to personal Caldav settings (Preferences - Caldav/CArddav sync - Location calendar to sync)
Can you help with this?
Thanks!
BR,
Z
  • created
    Oct '24
  • last reply
    Oct '24
  • 10
  • 353
  • 3
  • 1
    link
For us to check that, we need EGroupware’s CalDAV log of that client.
Switch it on, or empty it, if already running.
Reproduce just that case: create the event, modify it, … AND save and attach the log here.
As client i used iPhone XS with the latest OS version in built in calendar. I’ve added caldav from the settings app.
After making changes in events, i checked results in Thunderbird also. Same “stucked” event appear in Thunderbird, but not on the web calendar.
Additional to what Ralf wrote about the account in my.egroupware,org you may check if the web calendar with filter “owner too” may also show that additional event. Ower to shows also events where your user is not participants, but which was created with your account, so you are the owner.
Birgit
I checked this also, and “Owner to” filter doesn’t show the related “stuck” event. this event only shows in the client side and only in the resource calendar.
