Hi John,
if the event is marked as privat, only the participants will see the
details.
Birgit
I know there have been several questions on this, but AFAIK this one hasn’t
been asked before.
I have two groups, ‘Committee’ and ‘Secretaries’. They need to share a
calendar for most events, but some events need to be private to the
’Committee’ group (Not to an individual, all that group need to see and
alter the event)
Is it possible to set up the ACL so that some events are seen by both
groups, but other events are only seen by one group?
It doesn’t matter if they see there is an event, just as long as they can’t
see any details.
If it can’t be done then I will add a new control to the edit template to
make events private to a group, but I thought I’d ask before I start coding
Thanks
John
Birgit Becker
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
cell +49 (0) 170 3147833
mailto: bb@stylite.de
www.stylite.de
Geschäftsführer:
Andre Keller und Ralf Becker
USt-ID: DE214280951
The ultimate all-in-one performance toolkit: Intel® Parallel Studio XE:
Pinpoint memory and threading errors before they happen.
Find and fix more than 250 security defects in the development cycle.
Locate bottlenecks in serial and parallel code that limit performance.
http://p.sf.net/sfu/intel-dev2devfeb
