Perhaps this is a configuration issue, but I am finding that calendar entries
added via Kontact (via GroupDAV) are placed at the wrong timezone offset–they
are one hour earlier than they should be.
In the server’s /etc/php.ini as well as Kontact, I have the timezone set to
’America/Chicago’. EGroupware displays the proper timezone and time in Common
Preferences.
If I create an event for next week (January), it will appear in EGroupware one
hour earlier than it should. However, if I place an event in July (well after
the next change to Daylight Savings Time), it will appear correctly.
Is there something I need to do differently here to get GroupDAV calendar
entries to work properly?
Thanks. -A
Anthony - http://messinet.com - http://messinet.com/~amessina/gallery
8F89 5E72 8DF0 BCF0 10BE 9967 92DC 35DC B001 4A4E
