Hi Francesco.
Most of the time, a database upgrade works quite smoothly. Minor problems can always occur with such an old database.
We offer the database upgrade as a service:
As a rule, we calculate 2 hours. That usually fits.
You load your old database into an EGroupware trial, we do the update and fix errors and problems if necessary. Afterwards you can test and download a backup and install it on your system.
So before you work on it yourself for a long time and then it doesn’t work out…
Especially if you work for an organisation/company. You don’t have to do everything yourself.
