I’m testing EGW.
We’ve tried to syncronize EGW with iCal using calDAV protocol.
If I do…
- create a calendar entry with one participant in EGW
- Wait for iCal to get info from EGW
- edit the new calendar entry in iCal and set a new duration, date… (but keeping one participant)
- click save and the calendar in iCal and in EGW show the updated task
If I try to do the same with more than one participant I can do it on EGW but if I edit and click save in iCal no changes are accepted.
Any suggestion?
Regards
