HI Mathieu,
I’m trying to use groupDAV to synchronize my egroupware with an iPad
(iOS7). While personal normal (ie. not account) contact synchronise
correctly both side, I can’t see account contacts on the iPad. When I
check /http://host/egroupware/groupdav.php/addressbook// my account
contacts are indeed displayed. I checked preferences and the only option
that I found related to contact filter allow to hide account contact (ie
that’s not this parameter which is preventing me from seeing account
contact on the iPad).
iOS displays all addressbooks in your addressbook home
(https://domain.com/egroupware/groupdav.php/username).
Just go to your CalDAV/CardDAV preferences in EGroupware and check under
additional addressbooks to sync “Accounts”.
Looking at the vcard (see attached file for example of account and
non-account contacts, 3.vcf will appear on the iPad while 25.vcf won’t),
here are the diffences :
- The “N:” line is filled with the group Account
- the “FBURL:” line appears
Do you have any idea of what I could do to make the account contacts
appears as well as other egroupware contacts on iPad?
Kind regards,
mathieu
TeMPO Consulting
9, rue du Parc
67205 Oberhausbergen
France
http://www.tempo-consulting.fr
Tel : +33 3 88 56 82 17
Fax : +33 3 88 56 46 64
