Hi All,
We’re new user of EGW, so the question may be trivial. I’m finding a problem I can’t solve. I created some projects using the Budget + price list accounting type. For a period of time, accidentally, I modified the budget option and now I have some projects for which the accounting is provided and others for which it is not.
I can’t find any way to modify projects that don’t have accounting and tell EGW to consider it for projects created without accounting.
Any suggestions?
Gabriele
