Hi Hans-Jürgen,
Hans-Juergen Tappe schrieb:
Hi Klaus!
Klaus Leithoff schrieb:
There is a Class String.php in the same directory as the iCalendar.php
For you:
/var/www/groupware/phpgwapi/inc/horde/Horde/
The following additional line fixes this problem in trunk:
icalsrv/icalsrv.php:
143: require_once EGW_SERVER_ROOT.’/phpgwapi/inc/horde/lib/core.php’;
Can you please fix this even though icalsrv is not officially supported?
Commited the fix.
My problem currently is that caldav currently does not (yet?) support
synchronizing tasks, so I am still using icalsvr for that. I also still
use icalsrv for syncml PDA synchronization with funambol. Will caldav be
able to replace icalsrv completely in the future?
GroupDAV is already supported for tasks (InfoLog), but not yet CalDAV.
With Funambol DS server you can use CalDAV/GroupDAV:
http://bionicmessage.net/?q=node/2
[open style of IT]
Morschheimer Strasse 15
67292 Kirchheimbolanden
fon +49 (0) 6352 70629-0
fax +49 (0) 6352 70629-30
mailto: rb@stylite.de
www.stylite.de
www.egroupware.org
Nigel Vickers und Ralf Becker
