just tested it on my developer machine and a 14.2 in our hosting
works without the described flaw.
comment is saved upon the first upload.
sorry - i cannot reproduce the described behavior.
best regards
klaus
Morschheimer Strasse 15
D-67292 Kirchheimbolanden
Tel. +49(0)6352 706290 | Fax +49(0)6352 7062930
Mail: kl@stylite.de www.stylite.de | www.egroupware.org |
www.facebook.com/EGroupware
VAT DE214280951 | Registered HRB 31158 Kaiserslautern | Germany
E-Mail written with EGroupware: The software for advanced business
communication
Hello,
There is bug in Phpbrain (on egw 14.2) :
when uploading a file for the first time, the comment is not saved.
Uploading the same file again, the comment is working…
Thank you,
Thomas
One dashboard for servers and applications across
Physical-Virtual-Cloud Widest out-of-the-box monitoring support with
50+ applications
Performance metrics, stats and reports that give you Actionable Insights
Deep dive visibility with transaction tracing using APM Insight.
http://ad.doubleclick.net/ddm/clk/290420510;117567292;y
One dashboard for servers and applications across Physical-Virtual-Cloud
Widest out-of-the-box monitoring support with 50+ applications
