I am new to EGroupware and I am trying to install on my Windows hosting provider using IIS/PHP/MySQL. I have copied all files up, renamed .htaccess file, run through pre-requisites (complained about a gantt chart tool missing) and set the header.inc.php file.
When I try the next setup step, I log on using the admin user and it says:
Your database is working, but you dont have any applications installed
All items have red crosses next to them and all other tasks say:
Not ready for this stage yet
I click on Install All Applications (I wonder if there should be anything else listed in this section as there is nothing) and it simply goes back to the login page, I am stuck in a loop. There are no error messages, and nothing extra is listed when I check extra debugging messages.
Anyone have any idea what is wrong? Could it be file access permissions? Database access permissions? I have checked most settings and they seem ok.
I am just getting to clue as to what is wrong and the installation documentation is not the best and offers no hints.
Any help is appreciated otherwise I will have to move on to look for another open source collaboration platform to install instead.
Many thanks,
Doug
