Is there any way to configure the Knowledge Base editor to create html tables?
I have a few older articles that I pasted tables into but I can’t modify them
Should use your personal preference: Common preferences >> Text editor settings >> Features of the editor
Thanks Ralf,
Thats exactly what I needed.
