I want to use CAS login. I have setup a CAS server which works (tested with
another service).
How can I debug this? I think I have configured everything. At “Authentication
/ Accounts” I have enabled CAS, but it isn’t working. I checked
$GLOBALS[‘egw_info’][‘server’][‘auth_type’] inside login.php but it is not
set to CAS.
I checked the database configuration and it should be CAS.
Thanks.
*Ser freak no és imprescindible per ser informàtic, però ajuda.
*La vida no ha de ser feliç, ha de ser plena.
*Abans d’imprimir aquest missatge, pensa en el medi ambient.
