The setting ./agenda is not a known URL for the calendar access. Has to be ./calendar Sync with an E61 is more or less working as well against 1.2. Unfortunately the ./calendar does not contain the handling for infolog tasks and phone notes. These values are not synced. Infolog Notes are synced in ./notes and apear in Notes in the phone. I saw there changes in the api.php in trunk. Would these changes be in regards with the handling of those infolog notes for syncml clients not having a separate ./task URL for the task handling?
Hi All,
I would like confirm that the Nokia N70 is working with the builtin SYNCML client to EGROUPWARE.
The following things need to be checked to besure that it works.
Setting up SYNCML for Nokia N70
Menu --> Connect --> Synchr.
Than select options --> nw synchr. profile
It wil ask if you would like to copy settings from a previous installed sync.profiel. Chose NO
Name Synchr. Prolie --> choose a name
information carrier --> choose web
access point --> choose your ISP provider
Hostadress --> your adres to your egroupware/rpc.php
Port --> 80
Username --> your egroupware username ( if you are using multiple domains than your username will be username@yourdomain.com )
Password --> your egroupware password for the above user
Sync. send allowed --> YES
Sync. Send accept --> YES
Network verrification --> NO
Than press then right navigation key, you are now in the specified settings of contacts, agenda, notes.
Contacts:
Select Contacts --> select YES
External database --> Enter the following ./contacts ( watch out is case sensative )
Synchronisatietype --> Normal
Agenda:
Select Agenda --> select YES
External database --> Enter the following ./agenda ( watch out is case sensative )
Notes::
Select Notes --> select YES
External database --> Enter the following ./notes ( watch out is case sensative )
Wel thats all.
Thanks for the great software, still waiting for an email client support multiple accounts.
With dear regars,
Gerwin van den Brink
The Netherlands
[/quote]
