You could do something similar to the command-line client, which uses a
"root_" prefix to the username to indicate you want root access. Which
would in turn set a flag in the session and if that’s present set
egw_vfs::$is_root = true;
Which gives you root access, 'til the session terminates.
Other solution would be to create a pseudo user and assign him an
externded ACL granting access for /.
Dear All, how is it possible to connect as Superuser to the Filemanager using
WebDav/NetDrive? I think that is must be possible by altering the
"webdav.php" file but so far I have not been successful. The risks are
understood but being able to do so will make it much easier to manage
customer files and folders. Any tips or help appreciated.
View this message in context: http://egroupware.219119.n3.nabble.com/Connect-as-Superuser-via-WebDav-NetDrive-tp3396344p3396344.html
Sent from the egroupware-users mailing list archive at Nabble.com.
All the data continuously generated in your IT infrastructure contains a
definitive record of customers, application performance, security
threats, fraudulent activity and more. Splunk takes this data and makes
sense of it. Business sense. IT sense. Common sense.
http://p.sf.net/sfu/splunk-d2dcopy1
