Hi Lubos,
I’m not aware of any problem in that area. I was specifically working on
it for our Univention Support.
I can generally describe you how the process works and you might be able
to figure out what goes wrong for you:
a) Account creation by admin_cmd_edit_user triggers “addaccount” hook,
which emailadmin implements.
b) emailadmin_hooks::addaccount() calls self::run_plugin_hooks(), which
runs hook for all imap and smtp plugins for accounts valid for multiple
c) creation of INBOX happens only in Cyrus IMAP plugin (if a valid admin
account is configured!). We do not support that for Dovecot or any other
IMAP Server. AFAIK all IMAP servers can be configured to automatic
create an INBOX for authenticated users.
d) creation of other folders (Sent, Draft, …) happens when mail app
connects and does not find configured folders
Are you using a package install or archives, in the later case you might
need to register hooks, as I think I might have changed something there.
Apart from general process description above, there’s not much what I
can do with the given information and without support contract we wont
look at your installation.
Hi, after upgrade from eGroupware-14.1.20141021 to eGroupware-14.1.20141205
EGW won’t create
mail account for new user anymore. I mean account (created by setup) witch I
have for all users.
When I try to go to mail application as new user, I allways get this error
"Could not open mailbox “INBOX”".
EGW can’t create mailbox on server for some reason for new user. I have EGW
with LDAP and cyrus-imap.
When I first create mailbox with external utility cyradm, then everything is
fine. But I need to create
this mailbox automatically after first new user login in EGW as it worked in
eGroupware-14.1.20141021.
Can you fix this bug in next release or advice how to fix it myself.
Thanks Lubos
