I have a script which creates infolog tasks and copies them with curl to egroupware. Is there a possibility to link them with the addressbook on creation?
It should be possible, depending on how you’re copying. You’ll need
to know the contact ID, but I think either info_addr or info_contact
are the fields you need to fill.
Nathan
Beautiful is writing same markup. Internet Explorer 9 supports
standards for HTML5, CSS3, SVG 1.1, ECMAScript5, and DOM L2 & L3.
Spend less time writing and rewriting code and more time creating great
experiences on the web. Be a part of the beta today
http://p.sf.net/sfu/msIE9-sfdev2dev
