Hi Jefferson,
I can reproduce it, if I switch session encryption on in header.inc.php
file:
$GLOBALS[‘egw_info’][‘server’][‘mcrypt_enabled’] = true;
As a temporary fix, you could set it to false, until I’ve fixed it and
build new packages.
After update my egroupware I am getting the error CSRF detected,
request terminated!.
How I can fix this?
I put the http error bellow.
Regards,
[Tue Jun 03 05:50:09 2014] [error] [client 10.16.15.10] CSRF detected
from IP 10.16.15.10 to POST /egroupware/setup/config.php, referer:
http://srvwiki.results.intranet/egroupware/setup/config.php
Array([csrf_token] =>
CeV7lNPDrFZr20RTlEKkmvI2deHKTXmw0YUM/zXCcUOqL9Y4m7rPWEIGbSISP5C/hjYeJuxeEiolI421gup05Q==[newsettings]
=> Array([vfs_storage_mode] => fs[files_dir] =>
/var/lib/egroupware/default/files[vfs_root_user] => [backup_dir] =>
/var/lib/egroupware/default/backup[temp_dir] => /tmp[webserver_url] =>
/egroupware[image_type] => 1[aspell_path] => /usr/bin/aspell[hostname]
=> srvwiki.results.intranet[default_ftp_server] => [ftp_use_mime] =>
[httpproxy_server] => [httpproxy_port] => [httpproxy_server_username]
=> [httpproxy_server_password] => [mail_server] =>
pop.results.com.br[mail_server_type] => imap[mail_login_type] =>
standard[mail_suffix] => results.com.br[smtp_server] =>
smtp.results.com.br[smtp_port] => 25[smtp_auth_user] =>
admin[smtp_auth_passwd] => [auth_type] => ldap[auth_type_syncml] =>
[auth_type_groupdav] => [http_auth_types] => [account_repository] =>
ldap[sql_encryption_type] => sha512_crypt[check_save_passwd] =>
[allow_cookie_auth] => [auto_anon_login] => [pwd_migration_allowed] =>
[pwd_migration_types] => [account_min_id] => [account_max_id] =>
[account_prefix] => [case_sensitive_username] => [auto_create_acct] =>
[auto_create_expire] => 604800[default_group_lid] => [acl_default] =>
deny[ldap_host] => srvldap0.results.intranet srvldap1.results.intranet
srvldap2.results.intranet srvldap3.results.intranet[ldap_context] =>
dc=results,dc=com,dc=br[ldap_search_filter] =>
(uid=%user)[ldap_group_context] =>
ou=Group,dc=results,dc=com,dc=br[ldap_root_dn] =>
cn=administrador,dc=results,dc=com,dc=br[ldap_root_pw] =>
[ldap_encryption_type] => sha512_crypt[ldap_extra_attributes] =>
[ldap_account_home] => [ldap_account_shell] =>
[ldap_allow_systemusernames] => [cas_server_host_name] =>
[cas_server_port] => [cas_server_uri] => [cas_authentication_mode] =>
Client[cas_ssl_validation] => No[cas_cert] => [ads_host] =>
[ads_domain] => )[submit] => Guardar), referer:
Learn Graph Databases - Download FREE O’Reilly Book
"Graph Databases" is the definitive new guide to graph databases and their
applications. Written by three acclaimed leaders in the field,
this first edition is now available. Download your free book today!
http://p.sf.net/sfu/NeoTech
