As far as I know, you use the extension CSV regardless of the delimiter.
’;’ is chosen because it is less common in the content of the fields
(which get of cause quoted, if they contain it).
So far any application I came across, capable of importing CSV, can
choose the delimiter.
Nathan Gray schrieb:
Ralf, now that you’re back, could you please shed some light on this?
Any reason in particular that CSV export is not CSV?
The CSV Export does have another problem, as far as I know.
It is regarding the export of records that contain carriage returns
and/or
line feeds.
I suggest some more testing before you do the change. The delimiting
char
may be a minor
matter.
I did not have the chance to have a closer look yet. Ralf had
something in
mind, as he designed
the delimiters and row separators as he did. As far as I know he
tested with
OpenOffice.
Best regards
Leithoff, klaus
“Nathan Gray” nathan@goarctic.com schrieb:
It was just pointed out to me that the csv export is actually
semicolon seperated, with a delimiting the record by default.
I think that changing the csv_options[‘delimiter’] to ‘,’ should make
it CSV by default, but I’m not sure about where to set the EOR marker
(not that it needs to be anything else).
Should I make this ; -> , change?
Nathan Gray
nathan at goarctic dot com
Telefon +49 (0)631 31657-0
