1 / 3
Feb 2016
Is there a way to copy single lines of text from an infolog entry without having to double click and “open” the entry. The “CTRL” key method isn’t useful for me becasue it forces me to copy the entire entry . I just want 1 line out of the entry.
Thanks in advance
Mr Johnathan Bravo
  • created
    Feb '16
  • last reply
    Feb '16
  • 2
  • 1.2k
  • 2
  • 3
    links
Hi Jonathan,
With holding Ctrl (or Cmd on a Mac) you copy just what you select by
marking it with the mouse, one row or a couple of words.
Thanks in advance
Mr Johnathan Bravo
Thanks for the quick response.
That functionality doesn’t work at all in Firefox. In firefox it doesn’t allow you to highlight anything it just puts a box around the entire text block and only allows you to copy the entire block.
In Internet explorer 11 (tested on w7 and w10) the Marking always starts from the top of the entry and goes down to the mouse only. So if I want a single line of text from somewhere in the middle of the entry I can’t do it.
Chrome seems to be the only browser that it works properly in.
Mr Johnathan Bravo
