I have the same problem with the list of users. I partially resolved it
by selecting the DB session mode (instead of php session).
You can select that in the header.inc.php in this part:
** eGroupWare can handle session management using the database or
** the session support built into PHP4 which usually gives
**better performance.
** Your choices are ‘db’ or ‘php4’
$GLOBALS[‘egw_info’][‘server’][‘sessions_type’] = ‘db’;
But some services are unavaible like for example syncml.
Gauthier
System is FreeBSD 4.11
Apache 1.3.34
PHP 5.1.2
I had upgraded to eGW 1.2.RC8 from 1.0.009, and now recently upgraded to
PHP5 and eGw 1.2-1.
Everything seems to be working OK so far. I even have iCalsrv NG working
with my Macosx iCal.
Now I am seeing one problem. The “Current Users” section on the top-right
corner of Admin screen is always showing “0”, no matter how many persons log
in.
Clicking on it, takes you to the “Admin - list current users” screen, and
sure enough, that displays an empty table for the current users.
Before this would show all users, including myself.
Any ideas on how to fix this?
regards
http://sel.as-us.falkag.net/sel?cmd=lnk&kid0709&bid&3057&dat1642
Gauthier DOUCHET
Projet BX12
06.75.22.59.53
gauthier.douchet@bx12.info
6 boulevard Anatole France
90000 BELFORT
