EGW: version 1.8
I have problem with custom fields (Resources application). I created
some custom fields. I displayed some of these custom fields by
e-template. I choose Label, and ${row}[#custom] as name.
If I switch columns “custom fields” by the “Select columns” dialog at
the Resources page (frontend), everything is ok.
But when I switch off columns “custom fields” by the "Select columns"
dialog, there are no values even in my custom fields columns defined by
eTemplate.
I want to have displayed only some custom fields, and in the columns
defined by me. But it does not work if I disable “custom fields” by the
"Select columns" dialog
Thank for advices.
Pavel
