Hi, all.
I’m currently involved in several global non-profit projects, and I’m
currently looking for a kind of framework where custom web forms can
somehow be easily created (I hope I have described correctly the idea),
and egw has some approach, but I’m not sure how good it is without
further template development. Let me expose one example to find out how
good it is (or not).
Let’s take that for one project a form with custom fields is needed, in
order to just enter data (processing will come later, but looks like
it’s the easy part). Specifically, I need:
- A way to enter some data (just a few fields, including country and
date of birth) for people (it might be treated as contact, resource or
something else).
- Then, from a custom form, I need two different “fields” to search
and link previously entered people (take the two persons something
similar to “host” and “guest”, or “reporter” and “assigned to”).
- In the same form, there will be some extra text fields with no
special handling.
The data in the form is one record, and there will be many thousands of
records. Entering data will be a hard work, and there will be many
people in many places entering it (that’s why a framework is needed).
Maybe even the users can be restricted the queues/categories, etc they
can create records into, or a per user default assigned.
Then, a query method for the recorded data is needed. I have in mind the
tracker form, capable to filter data (I’m thinking right now that every
record could be even a tracker item), and it would be even better that
every record could be treated in a way that a status could be assigned.
Except for this last, the query will be mostly with a merely statistical
purpose, i.e., to get just a number of records with the specified
criteria, more than the details themselves.
Well, I might be forgetting something, but at this time, this is the
most relevant I’m able to think right now. I would like to have a
prototype for next thursday evening, but if it’s not possible, it could
wait another week, unless you advice to forget egw for this. In this
latter case, I’d like to know other possibilities.
I forgot to mention that I intend to have full access to the server, so
if some operation is needed, this should be no problem.
Thanks in advance.
GPG Key at http://keyserver.pgp.com |
