Hello ,
I have a problem with the tracking system only, for only one user. When he logs in he gets an error :
Instance=default, User=dgrigorov, Request=POST http://service.uniken.bg?menuaction=tracker.tracker_ui.index&ajax=true, User-agent=Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/69.0.3497.100 Safari/537.36
[10-Oct-2018 18:40:52 Europe/Sofia] Database error (EGroupware\Api\Db\Exception\InvalidSql): Invalid SQL: SELECT SQL_CALC_FOUND_ROWS egw_tracker.*,egw_tracker.tr_id AS tr_id FROM egw_tracker LEFT JOIN egw_tracker_assignee ON egw_tracker.tr_id=egw_tracker_assignee.tr_id WHERE egw_tracker.tr_tracker IN (103,33,30,104,29,34,35,31,32) AND (1514757600 <= tr_created AND tr_created < 1546293600) AND (tr_private=0 OR tr_creator=1011 OR tr_assigned IN (1011,-1,-1009,-3)) GROUP BY egw_tracker.tr_id, egw_tracker.tr_summary, egw_tracker.tr_tracker, egw_tracker.cat_id, egw_tracker.tr_version, egw_tracker.tr_status , egw_tracker.tr_description, egw_tracker.tr_private, egw_tracker.tr_budget, egw_tracker.tr_completion, egw_tracker.tr_creator , egw_tracker.tr_created, egw_tracker. tr_modifier, egw_tracker.tr_modified, egw_tracker.tr_startdate, egw_tracker.tr_duedate, egw_tracker.tr_closed, egw_tracker.tr_priority, egw_tracker.tr_resolution, egw_tracker.tr_cc, egw_tracker.tr_group, egw_tracker.tr_edit_mode,
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near ‘LIMIT 0,3’ at line 1 (1064)
This is only for him and only with the tracking system, all other accounts and the apps are all working.
All help will be really appreciated.
