Hi Ki,
Hi Ralf,
How will cache be updated from the database? It seems I am running the
old config values when run in async. Thanks.
Have you updated your checkout with my fixes AND cleared the cache after?
Whenever a change happens, we invalidate the cache.
When value is needed the next time, it is read from database.
It could be, that the cache backend you use differs between Apache and cli.
Are you using APC(u)? If yes, do you have it enabled for cli too?
As a test you can force Apache and cli to use same cache backend, eg. by
explicitly specifying it in header.inc.php:
$GLOBALS['egw_info']['server']['cache_provider_instance'] =
‘egw_cache_files’;
or in phpgwapi/inc/class.egw_cache.inc.php on line 83:
static $default_provider = array('egw_cache_files');
Make sure your cron-job runs as Apache user and not eg. root, because
then Apache can NOT update the cache!
From: “Ralf Becker-2 [via EGroupware]” [[hidden email]
</user/SendEmail.jtp?type=node&node=3999468&i=0>]
To: Ki Setargilop [[hidden email]
</user/SendEmail.jtp?type=node&node=3999468&i=1>]
Date: Fri, 18 Jul 2014 03:15:38 -0700 (PDT)
Hi Gil,
Hi Ralf,
I think the issue here occurs i the function init_static under
config.php of phpgwapi. Do i need to comment that out? Thanks.
If you comment whole init_static out, config will stop working!
You could comment
if (!(self::$configs = egw_cache::getInstance(CLASS, ‘configs’)) ||
!is_array(self::$configs[‘phpgwapi’]))
Then config is never read from cache, but always from database. This
will lead to a slower system, but will work.
If you have a problem with caching, which is not yet fixed, report or
debug it and we will fix it.
