Hallo liebe Community ich habe diese Version im Einsatz:
egroupware-docker (23.1.20230524) hardy; urgency=low
jedes mal wenn ich einen neuen Benutzer anlege erhalte ich diese Fehlermeldung im Webfrontend:
Datenbank Fehler
Unknown column ‘egw_addressbook.egw_accounts.account_id’ in ‘order clause’
/usr/share/egroupware/api/src/Db.php (828)
folgendes steht im docker-nginx.log:
2023/06/12 10:48:55 [error] 21#21: *73580 FastCGI sent in stderr: "
PHP message: Datenbank Fehler (EGroupware\Api\Db\Exception): Unknown column ‘egw_addressbook.egw_accounts.account_id’ in ‘order clause’ (1054)
PHP message: File: /api/src/Db.php, Line: 828
PHP message: #0 /usr/share/egroupware/api/src/Db/Deprecated.php(64): EGroupware\Api\Db->query()
PHP message: #1 /usr/share/egroupware/api/src/Db.php(2287): EGroupware\Api\Db\Deprecated->query()
PHP message: #2 /usr/share/egroupware/api/src/Storage/Base.php(1036): EGroupware\Api\Db->select()
PHP message: #3 /usr/share/egroupware/api/src/Storage.php(483): EGroupware\Api\Storage\Base->search()
PHP message: #4 /usr/share/egroupware/api/src/Contacts/Sql.php(703): EGroupware\Api\Storage->search()
PHP message: #5 /usr/share/egroupware/api/src/Contacts/Storage.php(753): EGroupware\Api\Contacts\Sql->search()
PHP message: #6 /usr/share/egroupware/api/src/Contacts.php(2848): EGroupware\Api\Contacts\Storage->search()
PHP message: #7 /usr/share/egroupware/api/src/Accounts/Sql.php(565): EGroupware\Api\Contacts->search()
PHP message: #8 /usr/share/egroupware/api/src/Accounts.php(351): EGroupware\Api\Accounts\Sql->search()
PHP message: #9 /usr/share/egroupware/admin/inc/class.admin_ui.inc.php(382): EGroupware\Api\Accounts->search()
PHP message: #10 [internal function]: admin_ui::get_users()
PHP message: #11 /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php(622): call_user_func_array()
PHP message: #12 /usr/share/egroupware/api/src/Etemplate/Widget/Nextmatch.php(369): EGroupware\Api\Etemplate\Widget\Nextmatch::call_get_rows()
PHP message: #13 [internal function]: EGroupware\Api\Etemplate\Widget\Nextmatch::ajax_get_rows()
PHP message: #14 /usr/share/egroupware/api/src/Json/Request.php(204): call_user_func_array()
PHP message: #15 /usr/share/egroupware/api/src/Json/Request.php(104): EGroupware\Api\Json\Request->handleRequest()
PHP message: #16 /usr/share/egroupware/json.php(130): EGroupware\Api\Json\Request->parseRequest()
PHP message: #17 {main}
PHP message: # Instance=default, User=psch
Woher kommt der Fehler?
Wie kann ich ihn beheben?
