Hello,
Thanks a lot four your answer.
I have 3 logs of dovecot active (messages, error and debug).
Error is empty. In the other logs I can’t find anything looking like what you suggest.
At the moment I have following error in the PHP log file :
[Wed Apr 02 09:45:32 2014] [error] [client 10.52.30.178] Net_IMAP::disconnectnot connected!, referer: http://10.52.30.176/egroupware/index.php?menuaction=felamimail.uifelamimail.viewMainScreen
[Wed Apr 02 09:45:32 2014] [error] [client 10.52.30.178] defaultimap::disconnectnot connected!, referer: http://10.52.30.176/egroupware/index.php?menuaction=felamimail.uifelamimail.viewMainScreen
I find the following in the dovecot :
Apr 02 09:43:47 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24066, TLS
Apr 02 09:43:48 imap(sw2@sdmonv.info): Info: Connection closed bytes=1635/3818
Apr 02 09:44:38 imap-login: Info: Login: user=mr2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24151, TLS
Apr 02 09:44:38 imap(mr2@sdmonv.info): Info: Connection closed bytes=1623/3810
Apr 02 09:45:04 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24172, TLS
Apr 02 09:45:04 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=644/3866
Apr 02 09:45:04 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24174, TLS
Apr 02 09:45:04 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=173/1258
Apr 02 09:45:10 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24180, TLS
Apr 02 09:45:10 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=173/1258
Apr 02 09:45:10 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24182, TLS
Apr 02 09:45:10 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=620/3802
Apr 02 09:45:32 imap-login: Info: Disconnected (no auth attempts): rip=10.52.30.176, lip=10.52.30.176, TLS handshaking: SSL_accept() failed: error:14094418:SSL r
outines:SSL3_READ_BYTES:tlsv1 alert unknown ca: SSL alert number 48
Apr 02 09:45:36 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24194, TLS
Apr 02 09:45:36 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24198, TLS
Apr 02 09:45:36 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24202, TLS
Apr 02 09:45:36 imap(sw2@sdmonv.info): Info: Disconnected: Logged out bytes=654/2911
Apr 02 09:45:36 imap(sw2@sdmonv.info): Info: Connection closed bytes=157/1292
Apr 02 09:45:37 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24204, TLS
Apr 02 09:45:37 imap(sw2@sdmonv.info): Info: Disconnected: Logged out bytes=606/20586
Apr 02 09:45:37 imap(sw2@sdmonv.info): Info: Connection closed bytes=598/14360
Apr 02 09:45:37 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24206, TLS
Apr 02 09:45:37 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=620/3802
Apr 02 09:45:37 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24213, TLS
Apr 02 09:45:37 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=173/1258
Apr 02 09:45:37 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24214, TLS
Apr 02 09:45:37 imap(sw2@sdmonv.info): Info: Connection closed bytes=1635/3818
Apr 02 09:45:38 imap-login: Info: Login: user=mr2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24216, TLS
Apr 02 09:45:38 imap(mr2@sdmonv.info): Info: Connection closed bytes=1623/3810
Apr 02 09:45:45 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24226, TLS
Apr 02 09:45:46 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24228, TLS
Apr 02 09:45:46 imap(sw2@sdmonv.info): Info: Connection closed bytes=934/19794
Apr 02 09:45:46 imap(sw2@sdmonv.info): Info: Connection closed bytes=672/17090
Apr 02 09:45:48 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24230, TLS
Apr 02 09:45:48 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=620/3802
Apr 02 09:45:49 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24232, TLS
Apr 02 09:45:49 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=173/1258
Apr 02 09:45:53 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24234, TLS
Apr 02 09:45:53 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24238, TLS
Apr 02 09:45:53 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24242, TLS
Apr 02 09:45:53 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=346/1996
Apr 02 09:45:53 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=171/1295
Apr 02 09:45:53 imap(service.b.nl2@sdmonv.info): Info: Disconnected: Logged out bytes=650/4329
Apr 02 09:45:53 imap-login: Info: Login: user=service.b.nl2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24244, TLS
Apr 02 09:45:54 imap(service.b.nl2@sdmonv.info): Info: Connection closed bytes=1033/2802
Apr 02 09:45:58 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24246, TLS
Apr 02 09:45:59 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24248, TLS
Apr 02 09:45:59 imap(sw2@sdmonv.info): Info: Connection closed bytes=223/2557
Apr 02 09:45:59 imap(sw2@sdmonv.info): Info: Connection closed bytes=187/3772
Apr 02 09:45:59 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24250, TLS
Apr 02 09:45:59 imap(sw2@sdmonv.info): Info: Connection closed bytes=173/1269
Apr 02 09:45:59 imap-login: Info: Login: user=sw2@sdmonv.info, method=LOGIN, rip=10.52.30.176, lip=10.52.30.176, mpid=24252, TLS
Apr 02 09:45:59 imap(sw2@sdmonv.info): Info: Disconnected: Logged out bytes=161/2613
The IP .178 is from the user sw2
It sounds to mee as a disconnection problem, but I think my problem is that it is already disconnected for an unknown reason.
If any other log can help, please tell me.
Thanks for you further help
